Question about different sized wheels?
ablood21
Hauppauge, NY
2.3 (4 Cylinder)
225/70R14
Hello,
I have a 1995 Ranger XLT 4x2. The tires are 225/70R14. I blew a tire and am looking to replace them all. I found a set of wheels and tires being sold near me that are from a 2011 Ranger XLT. They are 235/70R15. Would I be able to swap them out? Would I have to space the new wheels to fit? Thanks for your help!
-Adam
Welcome to TRS :)
Its all about Diameter of tire not the rim/wheel size
Current diameter is 26.4", 8.9" width
New tires are 28", 9.3" width
Width is less that 1/2" difference so won't matter
Diameter is 1.6" difference, so 3/4" overall, so you would be good to go on that size
The front is where it matters the most for fender clearance when turning
You can have someone turn the front wheels side to side and see where the tire come the closest, if its more than a inch you are good
Thank you so much! I really appreciate the help!
Wise move switching to 15" wheels. Larger size 14" tires are getting hard to find & tread design very limited. Be aware that your speedometer will show less than actual speed with the 15s, don't want to attract the boys in blue!
Good call Rimjam
Forgot about speedometer with larger diameter tires
In 1995 Ranger still used speedometer gear setup, up thru 1997
So you just need to change the Driven Gear on back of transmission to calibrate for new tire diameter
Easy to do, 1 bolt
Info here: https://www.therangerstation.com/tech_library/Speedogear.shtml
