- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
As you may have heard my 85 Ranger 2.3L came missing a few parts. Among those would be Alternator, Power Steering pump, and associated brackets and hardware. I have the assorted brackets on the way. I'll rob the power steering pump from the wrecked 84 Ranger 2.8, it uses the same pump mounted different according to RockAuto. I'll buy a new alternator if I can't figure out where I stashed the one from the 2.8 a few years ago. Might not bother looking, even if I can find it I'll need a pulley and it's probably no good anymore.
1) RockAuto lists alternators with internal or external for my truck. Since I don't have the original there to compare, how do I know which style I need?
I also still need to acquire hardware to mount all of this.
2) Alternator pivot bolt is missing, what size and length is it? Is this bolt common to other Ford engines? Does it have a split spacer like the other Fords with this style alternator mounting?
3) Power steering pump and mounting bracket hardware is also missing. Looks like it is missing three bolts that hold the bracket to the block, and two that attach the bracket to another support arm. Once again can you tell me what size and length hardware goes in these locations?
How about the bolts that mount the pump to the bracket?
4) Finally, for now, I'm going to need to get bolts to attach the outer timing cover. This piece would be fairly easy to carry in, but any chance one of you knows the size off hand?
Sorrf it's not coherent, I should have been asleep three hours ago, and have to wake up for work in about 3 more.
TIA -JoshT
TIA -JoshT
