PVC Roll Bar???
ranger28
ok i know this sounds funny but i need one for some offroad lights my buddy suggested makin it out of pvc because i have no welder or bender eigher way i wanted i black so i was thinkin of yalls oppin of it its just gna be used for looks so let me no what yall think?
for starters it wouldnt be a roll bar then,more like a light bar .and instead of goin the getto route just try to find like a jeep light bar that goes on the roof
x3 will look like junk, youd be better off buying one
you could use some 2" conduit and a tube bender that would be about the same price. could be painted up good and would look better than pvc. again, it would be a light bar only andif you're short on funds and there is nothing on craig's list, that might be an option.
if your going to do something for lights, get some PVS, make a square the size of your roof, with a split center, so its 3 rows of pipe in a square, and install it down to the roof of the cab using Velcro (no joke), and install the lights in the center, its a temporary too.
A PVC roll bar would be pointless... it would be expensive, breakable, flimsey, and be a hazard after going so fast.
please don't. There was someone that did it though a few years back.
normally i'd say that this idea is so bad that it doesn't even justify a response from me.........but i am concerned enough that i feel the need to tell you that following through with this idea will doom our entire species
:icon_rofl: ROFL :badidea: Tell your buddy to keep his ideas to himself.
Lol, if you want to loose some perfectly good lights first time you get rolling at at good speed.
If your looking for a CHEAP way, go to an exhaust shop give them the demensions and have them bend it for you - would be sturdy enough to mount, and sturdy enough to mount your lights on, but that's about it.
x2. when people see its pvc, they assume you rode the short bus as a kid.
:icon_rofl::icon_rofl::icon_rofl::D
make one of these cheap :icon_thumby:
Thanks yall and i found some thin i could make check this out and see what yall think its on the white truck and of course i would make it look better and closer to the cab http://www.therangerstation.com/forums/showthread.php?t=25105 post a replay here to let me know if yall thijnk it looks good or bad or whatever you oppin is Thanks!!
thos are easy as hell to find. even if it for a full size get it and cut it to fit.its only fiberglass
