Push Rods and Rockers
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
Millersport, OH
Anybody got any recommendations for replacement push rods and rockers that are compatible with a comp 410 cam?
-plumcrazy
If you ask the cam company they will tell you to use the stock ones..
Big JIm
There is a company Delta Cams that makes a great set of heat treated pushrods and rocker arm assemblies with pressed-in inserts that guarantee MUCH less wear than the originals. The set is about 200$ with a 40$ core (If I remember correctly). My stockers were worn BAD at 100K miles. I thought they were the cause of my clacking, but they weren't, actually, even with all of the wear. I'm not pulling heads to replace lifters, and paying 40$ a pop for them either.
the push rods need to be 5.5 inches long and 988 valve springs and get the 422 cam if you going to get a cam dont waist your money on the 410
