push button switch
19841992
i have a 1992 ford ranger stx 4.0 5 speed 4x4 i checked all the fuses they are all good when i push the four wheel drive switch no lights come on no clicking what do i do should i buy a new switch or transfer case motor or what i am lost and need help any help is greatly appreciated thanks matt
Check the 'lil stopper bushing on backside of the gear in the electirc motor. That is what was wrong with mine. Used about 1/4in of vaccum hose to replace the toasted bushing. And now it works great:icon_thumby:
i'd be hitting up a junkyard... IF parts are needed
however you can test it.. you could bypass the switch and see if you get 4x4. or you could get a volt meter out and test for power before the switch, then after, then at the shift motor. have you look in the tech library about adjusting the shift motors or anything yet?
how would i bypass the switch to test the shift motor i havnt looked about adjusting the shift motors but thank you for the suggestions
I did all of the above mentioned on mine, did not fix it, finally pulled motor apart and found bad bushing. Also had bad bushing in the replacement i bought at the J-yard:annoyed: Now I have a spare motor:icon_thumby:
i restore classic cars for a career i think i can handle pulling the motor apart is there any thing that i need to be worried about when i take it apart if thats the problem
i'd start w/ the bushing in the motor... b/c that is the most common.
is there a rebuild kit for the motor or should i just take it apart and clean it what is the best way to bypass the switch so i can make sure the switch is not the problem
its just an electric switch. i took a fused wire and hooked to both sides of the switch. just completed the circuit... however, mine is a first gen w/ the overhead switch. i'd assume its the same thing.
and rebuild kit? you don't need it.... read the comment above about replacing the toast bushing w/ 1/4 of vacuum hose.
ok sounds good thank you both for all your great help
