atlsud
- May 11, 2010
- Automatic
What are the steps to purging the manifold of air when the system is empty?
The videos I've seen use the pressure in the system to purge the low and high side tubes and purge the yellow tube from the new refrigerant can. How do you purge the low and high side tubes when the system is under vacuum?
Thanks in advance!
Thanks in advance!
