I know what you're thinking....this guy's got the dumbest questions.
Anyway my 85 Grand Marq/Corwn Vic motor is missing the water pump pulley. (And all accessory brackets for some reason. Damn Leprechauns...) I am not using A/C or P/S so what engine do I need to look for to get a pulley? I would like to stay with a serp belt, but not sure what belt to get with only an alternator. And, would I need a tensioner pulley? If I went v-belt, I presume pretty much any 289/302/5.0 pulley system would work fine, and I am also sure that a belt would be easy to track down. But I would have to change the pulley on the alternator. And I don't know if the water pump spins the same direction as the crank or reversed as I have no memory of hoe the darn thing was on there with the A/C and P/S on the donor. Any of this make sense?
