meatshieldchris
- Sep 29, 2009
After finding conflicting answers, I figured out how to get mine off, and thought I'd post here.
I have two motors infront of me, one is a 1989 2.9, the other is a 1992 2.9. You must unscrew the center bolt about 1/4", remove all 4 pulley bolts (if there are any), clean the holes, and install the M8x1.25 bolts that come with the harmonic balancer puller. Push on the center large bolt (I center drilled a little divot to center the puller with, otherwise it walked off). Make sure it's all lined up straight, with the bolts inserted equal lengths, and it'll come off 1/4" easy. loosen the puller, remove the center bolt another 1/4", and do it again. Once you're so far out that there's no more threads for the center bolt, just give a few good tugs on the pulley on the outward direction. It's not heavy, but as it comes off the crank it's heavier than you think, and will smash your pinky into something else.
It doesn't matter if there's a washer or not, at least on these two 2.9's, if you remove the center bolt and try pushing on the crank, you're not actually pushing on the crank, you're pushing on the center of hte pulley hub which looks like it might be the crank. The only way you can see the crank is looking through the hole the center bolt came out of.
Don'ts:
Don't try to use a claw type puller that pulls on the edge, it'll chip the pulley and won't move it.
Don'ts:
