PS hose: must be a trick to the lower fitting?
Vince Waldon
I'm replacing the high-pressure power steering hose on my 1998 B4000... top fitting is easy access, but the bottom fitting goes into a manifold with three other fittings in close proximity and is tight tight tight.
I've tried a regular and ground-down 18mm wrench to no avail... not sure an 18mm crowsfoot would fit either. I could cut off the hose and just use an 18mm socket but that won't help when I install the new one. ;-)
Anyone figured this out?? Search reveiled a few people stuck where I am.. but no answers.
thanks,
Vince
You might try calling your local ford dealer and speak to the service dept. Ask the guy if he's a mechanic, he probably is, but if he's not, see if he'll ask one of his mechanics how he does that. I had a couple guys I could call about stuff. And wait a day or two, you'll have five or ten correct answers coming along, here on the forum.
Good suggestion... thanks... unfortunately both the Ford and Mazda shops in my neck of the woods are none-too-forthcoming for the do-it-yourself-er. In fact, the Ford shop told me the PS hose was discontinued and my only hope was a junkyard. ;-)
Gonna try to track down an 18mm crowsfoot but it's turning out to be real rare here as well... 17 and 19 yes, 18 nope.
