cbr600rx7
Ok people let's go ahead and get the flame on so we can get it out of the way. The truck is a high mileage 93 base model that the AC has not worked on in the last 10 years. Recently the PS pump has been making more noise and has started leaking fluid from the input shaft. The gear box also has some signs of a leak starting but it's not horrible enough to address yet. I wondered what would happen if I bypassed the system and ran a non AC belt for manual steering and was kind of surprised.
1: the truck doesn't make any noise. Other then the slight valve train noise it's very hard to hear the motor at idle. Keep in mind I also have a E fan.
2: the truck starts faster I assume this is just because there is slightly less force to over come from the PS pump and extra pullys.
3: the truck idled about 100 rpms higher then before. I don't have a explanation for it.
4: and yes there is a slight and I do mean slight power increase. I notice it the most in 5th gear. I would not justify doing this delete for power but we are probaly talking some where around 5hp realistically.
