- Aug 16, 2007
- Age
- 42
So last year at tough truck i chrushed my 1/4'' gas tank skid plate on the rocks and pushed the tank up into the pump and bent the pickup inside and ripped a hole in it. So i need t replace it anyway, A friend has a complete propane system including a set of big dual tanks that would fit pefect where i need them to go on the back of the Branger.. The setup is complete, not that old, and was puled from a carbed v8 truck. I run a Fuel injected 1994 4.0l Ford v6, Ive researched a bit and found they do make propane injection kits for these motors to the tune of $1000.. or more.
My question is. If i capped off the injector holes in the intake manifold or just cap off the fuel rail itself and leave the injectors in place. Could i make an adapter for the hat and install it into my intake hose? Has anyone done something similar to any other injected motor. I like how clean propane runs, mine floods out a bit now and every time i chamnge the oil it reeks like gas i knwo thats not good for the bearings and not to mention washing the cylinder walls clean.. Also, anyone running propane have any experiance with the "drip" oiling system? Thanks -Cody
