Project rednek ranger upgrades
looking good dude!!
any reason for not using a c bushing kit to correct your caster? like one of these - http://broncograveyard.com/bronco/c-613-c-bushing-kits-radius-arm-track-bar.html
Tryed them still wasnt enough , I wanted to do Hime joints anyway , I was replacing radius arm bushings every couple trips, the long arms where the main problem for the bad caster angel I couldn't get them high enough to make it right and my wedges are cast not the weld on's so its not so easy changing that plus that would still leave my pinion angle down too far
This set up should work good and be more maintnece free so I can spend more time on the trail and less in the shop
Got my arms finished the other day used a piece of 2" 250 wall Dom notched 1/4 wide cut down both sides of the tube cut down the stock arms and made them slide in then welded them up
Did you drill and tap your passenger side outer yourself or did you have someone do it?
thanks
So what happened to this build?? :icon_confused:
