worked on the wiring Today, got the 2.9 litter dizzy harness extened, change the 2.9l TPS plug to the 5.0 plug. all i have left is hook the Injector harness plug to the 2.9l harness(3 wires, power, injector bank 1 and 2 (bank fire)), hopefully if every thing works out this week i may be able to do a test fire
, assuming the 2.9 computer will run the 5.0(remember hearing it done a long time ago).
beside a driveshaft all i need know is:
1> f150 brake booster vacumn hose
2>figure out heater coolent line routing in conjection with intake and water pump(where pictures of stock f150 would have helped)
3>hook up throttle cable and f150 tv cable
4> run tranny cooler lines and High pressure fuel lines
5>setup Vacumn lines(by by emissions)
6> add fluids, tighted Torque converter bolts to flex plate, install starter, and wire , and add a belt
7> sit back and hear 5.0 open header rumble(if im lucky), once running gotta to get Drivelines and figure out what to do with heater box(intake sharing same place).
