project b2 resurected
alaskan155
washington
b2 been parked since april untouched, in oklahoma, finally picked her up this weekend and flat towed her to cheyenne, wyoming, so finally get to work on her again, and i got a auto hobby shop know to use with a lift and etc since im active duty military. so get to continue my buildup from where i left off, as soon as i get my testing done :clapping::clapping:, so will be posting in the next month or so to tell you the results of my 302/AOD/np208 swap(first time)
look at that cool truck 5.0 under there, cant wait to finish my testing so i can here her run again.
worked on the wiring Today, got the 2.9 litter dizzy harness extened, change the 2.9l TPS plug to the 5.0 plug. all i have left is hook the Injector harness plug to the 2.9l harness(3 wires, power, injector bank 1 and 2 (bank fire)), hopefully if every thing works out this week i may be able to do a test fire:icon_hornsup:, assuming the 2.9 computer will run the 5.0(remember hearing it done a long time ago).
beside a driveshaft all i need know is:
1> f150 brake booster vacumn hose
2>figure out heater coolent line routing in conjection with intake and water pump(where pictures of stock f150 would have helped):icon_confused:
3>hook up throttle cable and f150 tv cable
4> run tranny cooler lines and High pressure fuel lines
5>setup Vacumn lines(by by emissions)
6> add fluids, tighted Torque converter bolts to flex plate, install starter, and wire , and add a belt
7> sit back and hear 5.0 open header rumble(if im lucky), once running gotta to get Drivelines and figure out what to do with heater box(intake sharing same place).
