procomp 4wd lift
The stud extensions won't work, but the spacers and add-a-leaves will work. You will need a 2wd specific kit or if you buy that kit, you would have to go find a bolt that is longer than stock to use with that kit. Try Fastenal for bolts. I looked there once and they do have 3/4in bolts that you require. The 4wd trucks have different bolts if I'm not mistaken.
Edit:
I found this: http://cgi.ebay.com/ebaymotors/84-9...r_Truck_Parts_Accessories&hash=item4155a7ee69. It's from the same guy, but hopefully he should know that there is a difference between the 2wds and 4wds.
I've heard mixed things about poly spacers. You can try them out yourself if you want' Just keep an eye on them and if they start to crack, just replace the spacers with washers. It's the same idea.
check out the tech library for coil spacers made from washers, sounds half ass but its better than that junk they are selling there and lots strong and plenty of hard offroaders use it
i started thinking about buying the rc leveling colis and an add a leaf for the back so i could elimate spacers all together
Hey if you are looking for coil spacers check out this guy from ebay. Summit-engineering..........type in Ford F150 Bronco Explorer 4WD 2" Leveling Lift Kit FB2A
I bought a set last year from them........still need to install them......time and money.........anyways they are good quality and measure like 1 3/4 or so they are under 2"
if you read further down the spacers arent made from poly. they are delrin which is some really good stuff.
it might not be a bad kit. but i personally would go with leveling coils and either shackles or an AAL
That'll give you 2.625 in of lift. TTB/TIB lift ratio is 1.5:1.
