Rocker3829
- Mar 30, 2009
Hey y'all, lookin for some advice here on what I should with my ranger. Heres the backstory on my 1996 2.3L 5 Speed Manual Ranger
I was driving to class yesterday when I had to stop at a 4 way stop. I took off from the stop to realize that the motor sounded and felt like it was running rough. Long story short a friend of mine has helped me change 7 of the 8 spark plugs and wires and cleaned the MAF sensor and it is running a little bit better but it still is not perfect. It really rides rough in 1st and 2nd but once I get to higher rpms in 3rd and eventually into 4th and 5th it smooths out. I have disconnected the battery to clear the codes but doing that did not change how it runs.
I have the following codes:
P1443 (aux. Emissions)
P0303 (Cylinder 3 misfire)
P0171 (not sure what this one is)
P0420 (Cat.)
P0402 and P0401 (EGR Flow)
I guess the next thing to do would be to get new Ignition coil(s). Any help on what I should do next (and any advice on how to get to the 8th spark plug and wire behind the intake manifold) would be greatly appreciated.
P0420 (Cat.)
