Problems with lots of lift?
dude772
Solid Axle Swap
Caledonia, Ontario
Im curious what problems anyone has had with 6+ inches of suspension lift.
Specifically with driveline angles? what did you do to correct this?
driveshaft lengths...........lengthened driveshafts
driveshaft angles............reangled pinions on diffs
Also, your tie rods will be at horrible angles, even with the Superlift Superuner steering setup. You will need to fab up some new tie rods.
i think hes doing a SAS so it not as big of an issue, but would still ned addressing
Ah. That wasn't too clear until i read his signature.
i didn't want to complicate things by adding that, how much did you have to angle the pinions? and how much lift did you have?
i have about 6-7 but my wheel base is uber short which required much more angle
hell with it.. im just going to toss the dana under there with the right castor and see what happens lol.
Pitman arm....New
Brake lines...Longer or relocate.
Higher center of gravity...Drink less.
