Problem with transfer case
jpizzel84
CANADA
i recently bought a 98 ranger for $800 and when i bought it the previous owner said that it was stuck in 4wd. when i got it home i took the shift motor off the transfer case and tried manually shifting it between 2wd, 4wd high, and 4wd low. shifting it manually, it seemed to shift easy which led me to believe that it was a problem with the shift motor. when i set the truck in 2wd it would not move, only made sort of a skipping noise. i then tried in 4wd high and low and it made the same noise. i am pretty sure that i need a new transfer case but i was just wondering if anyone else out there has had this problem and held a solution?
thanks
