Denisefwd93
- May 20, 2015
- South East PA
- 4.0 V6
- Total Lift
- stock, may get leveling springs in front "somday"
- Tire Size
- 235
Prking brake & fluid lights
I have the red light for the parking brake and or the fluid level are they one in the same two lights in there?
I'm guessing it's the fluid level it was low but not completely empty is there a reset or a float switch in there somewhere that I don't see or haven't look for yet? The brakes work "okay" although we are going to go through them completely on each wheel probably have the rotors turned or replace the usual drill but in the meantime?
I know GM uses a pressure switch for the same situation I await your answers... thank you!
RABS is separate from this, correct?
I also use the search function on the group and I found this other thread seems to be the "fix"
http://www.therangerstation.com/forums/showthread.php?t=39584
