Printed Circuit Boards
Jaybird130
Bonaire
GA - USA
Other
Mazda B3000
Drive
2WD
3.0 V6
Good day all,
Need some recommendations on where to acquire printed circuit boards for the rear of an instrument cluster housing. The vehicle is a 1994 Mazda B3000 with an automatic transmission and a tachometer. On mine, the circuit board plastic is deteriorating and the copper circuits are starting to move leading to connection breaks and short circuits. I know the part is out of production but thought someone may know of an aftermarket shop that produces them. I also realize I could pick it up at a salvage yard or E-Bay, but it is usually attached to the instrument cluster housing, which I don't need. My instruments are fine. Plus, if it's been sitting in a salvage yard, it may also have the deterioration issues that I'm currently experiencing. Any help would be appreciated.
Thanks in advance,
Jay
Besides going full custom you're going to be stuck with junkyard or ebay
Pretty sure this is what the answer is. Ranger parts should swap so it opens up your options a little
Thanks y'all. I was afraid that'd be pretty much the answer. I appreciate it.
Jay
Jay
As more and more stuff like this comes up I start thinking that maybe going to aftermarket electronics is the answer for stuff that has aged to the point of unreliability
There are companies that make circuit boards if you have the skills to design it.
If this is the flexible circuit board like mine, I'd probably go point to point wiring. Nothing there draws any serious current and it's only about 25 wires.
Depending on the extent of the damage you may have success using copper tape for repairs. It should be available at hardware stores. Just trim it down to width and solder it to parts of the trace that are still good.
