Rangstang
- May 5, 2010
- Mesa, AZ
- My credo
- If it ain't broke, I can't fix it.
I swapped a 5.0L Explorer motor and accessory equipment into my Ranger a few months ago and decided to replace the compressor, accumulator, and orifice tube last week, evacuate, and charge it. I added the 9 oz. of PAG, 1/2 in the compressor and the other 1/2 in the accumulator as recommended. I evacuated the system and added 2 1/2 cans of 12 oz. R134. I pressure checked the system and I'm getting only 30 PSI on the low and 130 PSI on the high side on an 82° day and getting 40° out of the vents at idle. I'm pleased with the performance of the system, but I'm concerned about the low pressure even though the full capacity is said to be 30 oz. which is 2 1/2 cans.
Should I add refrigerant even though I've already filled it to spec capacity?
