pre fabbed roll cages
kris97ranger
Solid Axle Swap
lisle ontario
ive been trying to find a cage 6 up to an 8 point cage for my 97 ext cab ranger but on the jegs site there is only cages for an 1982 to 1994. would the cage for a 94 work in my truck? and if not where can i get one in one of these kind of kits? thanks
oh ya this is the jegs site i dont kno if its in another part im not so great with computers http://www.jegs.com/p/Jegster/Jegster-Ford-Roll-Cage-Kits/749661/10002/-1
________
PrisscumXXX
I would say it's probably a failure of them updating their site, unless it has something to do with '95up having airbags maybe? The cab interior dimensions have changed very little for pretty much the Ranger's entire run of existence (a 3" extension of reg cabs in '98 is the only major thing I can think of).
the 94 cage should fit in your truck just fine also i would do a 10 point and not put the bars out the back glass. then you have a dash bar and better chance of saving your cab if you roll it
ok the other thing is how much of the interior is going to have to come out if i go with the 10 point or any cage for that matter. the trucks still a dd for now
________
CHILDREN NEXIUM
You'll have to either notch or remove your dash to get the forward tubes and halo to fit.
pretty much take the whole dash out so you can put the forward bars in. your going to have to remove seats carpet and dash everything else should be able to stay
Just remember they still require welding and welding makes a heck of a mess on any sort of cloth or interior, I'd say gut the whole interior and save yourself the headache of having to try and do it after starting the cage install.
too bad you are so far away, there is a local guy that will install IHRA legal cages for $100 a point.
Does good work and is fast and honest...
100 a point **** that you can get a pre fabbed 10 point for 300
ya but having an experianced person do it and having it right the first time and all that is so handy... and 10 point u have to remove ur rear window and all that crap unless u just dont run the bars but then u paid extra $ for an 8 point
________
How to roll a blunt
i can get a prefabbed 8 point for less than 200 so it still not worth it to me. i want a cage bad
you must not value your life. Or your passengers.
how dont i value my life jegs cages are all approved and everything they are a safe cage.
