geoffthepoolguy
Driving home tonite on a beautiful North Carolina evening I had the windows down and the radio cranked up...all was well in the world
I pulled in the driveway, turned off the radio and the power window on the driver side will not go back up. Passenger side works fine but the drivers side..nothing except the dome light dims a tiny bit when I hit the window switch. The 30 amp circuit breaker for the PW's was warm to the touch which leads me to believe the PW motor is shot. Anyone agree? Also is there a way to "hand crank" the window back up? I took the door panel off and tried to lift the window/regulator assembly but it wouldn't move. Suggestions would be much appreciated.
Thanks,
Geoff
P.S. I did the Explorer leaf spring swap a few weeks ago....HUGE improvement! If anyone is remotely thinking about doing it, DO IT!!!
Thanks,
Geoff
