or.................it may not be a simple as some think. My entire day yesterday was devoted to the power steering pump and it still is not fixed. The pump its self is an easy swap if your willing like I was to cut the pulley off the front of the pump an forgo your core deposit!
After numerous trips to different parts houses for different makes of "power steering pump pulley" removal tools, all of which were to long to fit in space between the pump and the radiator, I gave in to carnal need to destroy something and broke out the old saws-all!
Now that it was laying on the floor with the pump shaft still in it, I put it in the vice and proceeded to remove the shaft, ( it was a matter of me wining at all cost ) it took a 3 foot bar and a whole lot of elbow grease to get it out. OK, so now I install the new pump and begin install of the said pulley............not my day.
The pulley is straight on the shaft, ( you can tell by standing on the side of the truck and rotating it by hand, no wobble etc. ) and when it reached about halfway on the shaft the pressure became so great that the threads inside the shaft let go and wall-ahh!
Guess I'll go home after work and break out the old saws-all again. Yeap, them press on pulleys are pure genius!! Some of the finest American ingenuity I have ever seen!!
Good luck with yours................
