bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
besides being patently obvious....the cam suggestions are a key factor.
what induction are you using? truck sd efi....stock crown vic efi?? mustang stuff? 2bb or 4 bbl carb?
where is your timing?
what headers and what type of exaust setup do you have?
is it efficiently constructed?
what was your compression ratio static?
did you degree and offset the cam or is it straight up?...if straight up did you degree and verify it?
373 and 33 in tires with a stout e head, 9.5 to one cr, h piped or single 3-3.5 factory equivalent headered exaust should exceed max 2.9 torque at 1800 rpm and beyond.
the 302 is venerable to say the very least, but natural low end torque is not in the cards unless specifically constructed to that end.
i ran straight pipes out the sides for years on a cobra engine....that was a dumb move....and i knew it, but my engine had plenty with the rest of the tuning so i tolerated the occasional kick downs. once i changed the setup with a fresh engine it was ok....i ran the low rpm truck cam expecting great results....and was very disapointed....but combined with a good exaust setup the difference was incredible for road holding power....didnt change the 0 to 60 really....but held od much better.
its pretty easy to get over 200 pounds of tq at 2000 rpm with the little guys with some patience.
