351rangerxxx
- Jun 28, 2009
- Automatic
your welcome
YOU HAVE A RARE DIESEL 2.9!!!!What the.......???????
This sounds egg-zakly like my '89 2.9L auto-xmsn....all sensors test good/cleaned all wiring connectors..fuel pressure is great/injectors are great/timing great/everything's great..truk has progressed from running on 4 cylinders to running on all 6 & smoking the tires when power braking....
However...it smokes black like a choo choo train until it gets to 50mph @ 3000 rpm.....then it clears up & launches at about 50 mph on up to 100mph...
Slow down below 45-50 mph and it's black smoke outta both exhausts all over again....
Now....the EEc won't supply any codes at all....using a code reader or a test lite......nothing....not even a blink...
Help....me burnt out...VA drugs don't help........
ok guys well i was wrong. the timing was correct before then we set it to 20 degrees BTDC and it ran better but not like it sould. still has the same problem just not as bad. not sure what else to do now. any ideas?
Anyone? Im at a loss to what step to take now. i'm thinking maybe the HallEffect switch in the dizy is bad. but i have no clue on how to test it. i haven't take the cap off to see if maybe the eye interuptor has come lose. dought it though.
good sudjestion but that just tells you if the eye works or doesn't i know it works cause the truck runs. it just has a funny idle, hesatates, & studders up too 3K.
