Well, as i searched tirelessly as others have; figured id put a little more information down then "splice wires". So here it is:
This is a really easy thing to do, you just need basic splicing tools, some wire generally 14 gauge, just dont go thinner then the cable your splicing and your fine, adding thicker wont hurt. Some wire connectors, 1-1 and 2-1. 1-1 wire connector for lengthening cables, and 2-1 for splicing passenger seat into drivers. if you want the memory function from your seats, youll have to figure that out yourself.
I started by attaching cables to pos and negative battery terminals, I was hoping to splice into a "hot" wire somewhere in cab but i didnt wanna wait to figure which one was hot.
Im not drilling or tearing apart dash to run this cable so this is how I did it. Ill try to put pictures into path order.
Hope this helps someone with an easy install, it explains basic installation. Obviously my wires are not the cleanest and i will clean them up now that i have it working.
