RangerRico
- Jan 23, 2009
- Automatic
My passenger door power door lock switch will lock/unlock the drivers side, but will not lock/unlock the passenger door. I have traced electric power all the way to the actuator and electric is good, leaving only the actuator to be the problem.
Now, how in the world do you take this apart to replace the actuator? There is a swivel rod linkage about half way up that attaches to the actual door latch mechanism, then the rod continues up from there to the push/pull knob. I can't get enough room to get inside there to remove the swivel rods, nor can I figure out how the actuator is mounted in order to remove it.
Any help would be appreciated.
