PlumCrazy's OG Build
Purple...I like that idea..
Sent from my DROID RAZR using Tapatalk 2
Wait, I had a good idea, that's something that doesn't happen often, I need to contact the Newspapers, and have a party.
Robert
Sent with a rooted copy of "Born in the U.S.A."
But since he is PlumCrazy, it has to be Plum Purple, not just any old purple.
Robert
sent with a light bulb, and rubber band.
Its going to be purple. Its settled.lol
Valve covers will be powder coated gray and the arooominumum parts will be cleaned and clear coated.
WoW, almost two pages of just what color the engine is going to be.
I'm tickled purple that you chose Purple, better then battle ship grey.
Robert
posted using a broken hair brush, and a can of WD40.
Picked a few more goodies yesterday from Summit. Rod and main bearings, high volume pump, and ARP rod bolts.
Pulled my front cover to reseal it and found this.
Just one chipped tooth...so I pulled the debris out and put the cover back on.lol When it lets loose Ill worry about it...probably throw some 4.88s in when the time comes.
Started re tacking the front joints but I ran out of wire..
Found that my exhaust hanger at the cat was broken again.
I added a support at the traction bar cross member.
Didn't do much today really. Picked up a new spool of wire, got my ujoint caps tacked up and burned the exhaust hanger together for the 4th time lol.
Replaced the tailgate cable since the old one was cracked and getting rusty.
You did better than me....
I backed the '36 out to work on it------12 hours later I put it up..... :annoyed:
(never put a wrench on it :bawling: )
Impressive!
You know where my trailer is if you need it when the times comes lol.
Impressive!
Way to be optimistic with the "when"....you could have said "if".,lol
But seriously I may need to borrow it someday.lol
Np. Keys are in the dually too IF the time comes lol
Off topic, but have you had time to dig into your Ranger brake issue? Just curious.lol
I havnt even pulled it off the trailer yet since the 6/1 trip. So no :(
I had open house this last weekend. So the garage had to stay clean last week. :( You should see it right now. Its super clean and organized. It looks like its not used.
Lol. I spent most of yesterday cleaning up the shop.lol Been working on Rustonco and there was like an inch of rust and dirt on the ground under it.lol We had to replace the entire rear hatch floor support and frame in the door jams, and plate the top of the frame.lol
