Hotrodlincoln
- Jan 7, 2008
- Automatic
So I put a new set of plugs in the 85 today. I gave each of the old ones a close check as I took them out.
The first one, cylinder 3 (the hardest one to get to) was actually a bit loose, clean, and looked 100% normal.
Second one, cylinder 2, straight up white. Apparently running pretty lean on that cylinder for some reason (bad intake manifold gasket maybe?).
Third plug, cylinder 1, clean, just like cylinder 3, looked great, not white not black, not ashed up, just clean as you would expect from normal combustion.
Fourth plug, cyl 6, had a fair amount of ash deposit. Not gunky black or green like a bad oil leak or coolant leak. It's a hard crusty tan-ish color buildup on the anode.
5th plug, cylinder 5, had a bunch of crud packed up around the plug on the outside, picked it all away with a small screwdriver and noticed the plug wasn't even close to tight. Didn't even use the ratchet to remove it, just put the socket on it and turned it with the extension.
(Who knows.) Anyway, plug was white (big surprise there huh?
) but otherwise clean. New plug in, tightened up just fine.
Last one, cylinder 4, comes out looking just like cylinder 6. Ash deposits, same color as before, about the same amount, just enough to coat the ground anode.
So this has me to wondering, What is causing the ash deposits, and why is cylinder 2 running lean? I'll recheck cylinder 5 in a couple weeks and see how it looks to make sure it's not still running lean too, but in the meantime...
I set plug gaps to .06. Starts great and runs like a purring kitten. Might have to unhook that MSD ignition box tomorrow and see if it still runs without it.
