dinosore
- Mar 12, 2013
Im going to apologize in advance for having to ask these questions. But can you identify these for me?
First is a hose that came apart while squeezing my hands in to do my plugs and wires. When I plugged it back in i noticed this tear in it. It connects to the air box but I couldnt follow the other end. What is the hose and its purpose?
here is where it connects to the air box...
I then noticed that my clutch fluid resivoir has a hose that goes down and connects to something under the brake booster...that something appears to be leaking despite my clutch fluid resivoir having what looks like substantial amount of fluid.
here is a close up with the trail of fluid present. What is this?
Lastly I noticed that a black capsule with what appears to be a plastic vaccum line has broken...no label on this picture but the black capsule is obvious and I'm holding the broken line that dissappears into my wires. What is this capsule? and where does this line go?
thanks all for any help. I have been trying to figure out a rough idle issue. would either of the lines i pointed to b the cause of the rough idle? i know i disconnected the air intake box line accidently while doing the plugs but if the tear was present before would it contribute to the rough idle or on the other hand if i caused that tear could that be causing a slightly rougher idle now even with new plugs and wires?
thanks all again
thanks all again
