please help
00RangerShavedAndDropped
Palm Coast, Fl
alright does anyone know how to remove the bracket holding the ac compressor and power steering i need to remove it to replace the air temp sensor bracket cause the end that went into the lower radiator hose broke any help would be much appreciated about to set this truck on fire lol
Remove the AC compressor bolts and compressor, then remove the three bolts through the front of the mount that go into the head (one will require you to turn the tensioner pully down to access with an extension), then there are eithe one or two bolts on the driver's side of the mount, one is a stud where the fuel lines attach with their mounting bracket and I think there may be one bolt lower.
