wasabijesus
- May 5, 2010
- Automatic
hey everybody. i got a 96 ranger with a big problem. truck will not stay running.. it sounds like its running outta gas. when i try to restart it idles fine for about ten seconds then just dies slowly with rpm going up and down then dead. at times when i start it it backfires and runs really rough.. tested fuel pressure ans was at 15 lbs so a bought a new fuel pump, same thing, changed map sensor, air idle motor and fuel pressure regulator.. when i swapped regulater truck fired up right away and ran perfect for 5, 10 min then back to same thing..
please help
thanx
david
please help
thanx
david
