Couple of things to check. Use a digital voltmeter. Start with a fully charged battery.
Check the battery voltage. ~12-12.5 V engine off . Start the engine and let it idle. Battery voltage should climb around 1 V to 13-14 V. No rise, or a small drop, charging system is not working.
With the engine off, check for 12V at the heavy red wire on the back of the alternator. No voltage?, check that fusible link or the connection at the solenoid.
With the key off, check for constant +12V at the A terminal of the 3 wire alternator connection. No voltage?, check the 15A alternator fuse in the engine compartment fusebox.
Check for voltage at the I terminal of the 3 wire alternator connector. +12V with the ignition on, (engine does not have to be running). 0V with the key off.
Don't worry about the S terminal. Internal wiring between the alternator and regulator.
