macd7919
- Dec 1, 2009
- Automatic
Hi Guys, you may have seen my other thread regarding the lean codes I was getting. Well unfortunately as of last Saturday I now have worse issues.
A bit of background:
Truck is a 1997 Ranger 4.0L with manual transmission and 160k on the clock.
I've had a P0171/P1443 light on for awhile now but the truck has been running fine outside of the light being on and annoying, maybe slightly low mpg. Occasionally it would go off on it's own but is generally on 98% of the time. I have had a cracked filler neck on the fuel tank for awhile which needs to be fixed but in the meantime I had started to look into some of the EVAP components and found that the EVAP solenoid wasn't working. Replaced that and checked voltage range on the EVAP sensor and it was good. So I was driving the truck here and there to get some drive cycles in and this is how I got to my current issue as described below.
So it all started as I was accelerating to get on the highway, I noticed a couple hiccups that weren't normal but nothing too terrible. I kept on going just cruising along and truck seemed to be running a little rough but was able to keep highway speed without much issue. I got off on my exit, stopped at light and immediately noticed the truck was misfiring at low speed/rpm. Now the truck misfires and bucks pretty bad below roughly 3000rpm. For instance, if I put the truck in 2nd gear and accelerate (slowly or quickly) from say 1000rpm the whole truck bucks and hiccups until about 3000rpm. Once it hits 3000 rpm it seems to clear up quite a bit. It doesn't completely go away above 3000rpm but maybe 75% better or so.
So long story short: Basically any type of load below 3000 rpm and the truck bucks and misfires. I have also noticed the smell of fuel from the exhaust after driving around the block. Ironically the check engine light HAS GONE OFF since all of this started happening
PRIOR to this misfire problem, say in the last 6 months, I have replaced:
MAF
Autolite Double Platinum Plugs gapped to approx .050 (With what looks like recent 8mm plug wires by previous owner) have approx 5k on them now if even that much.
DPFE Sensor
PCV Valve
Numerous vacuum lines
Cleaned throttle plate
Checked Intake manifold bolts
Replaced EVAP Purge Solenoid and all related vacuum lines
Tested EVAP sensor, tested good
SINCE THIS ISSUE STARTED in the last few days I have replaced/checked:
New Fuel Filter (old one didn't seem to be ancient and wasn't the original so it's been changed at some point).
Tested Coil Pack (Came out within range on primary and secondary and very close to resistance I tested on a brand new one at the auto parts store)
Cleaned MAF
Checked all the outputs on the coil for spark
Pulled plug wires one at a time while truck was running to see if there was a change, seemed about the same across the board no matter which plug I pulled)
Tested for intake manifold leaks with damn near a full bottle of brake clean (no idle changes)
Pulled a couple plugs to see what they looked like. Gap was fine, slight reddish hue to electrode (not porcelain).
From here I guess pulling the injectors? Truck has been running great (even though the check engine was on) then BAM! Running like crap and misfiring (especially at low rpm and load). On top of it all ironically the day after it started this misfiring stuff the check engine went off and hasn't come back on, WTH! So anyways, there has to be someone out there who's experienced this issue. I've googled and read a million different threads but they either never get resolved with the answer posted or they are something I've already tried. Hoping someone here at TRS can help me out before I go nuts messing with this thing. Thanks in advance for any help!
MAF
DPFE Sensor
PCV Valve
Cleaned MAF
