please help...aod wont go forward
reklis
just swapped a 302 into my 00 ranger and the transmission was working but slipping and now it wont go forward but reverse is perfect.. it could be bad idk
Is the TV (throttle valve) cable installed and properly adjusted?
the tranny was bad but thank you
Either way, make sure that cable is adjusted properly or you will fry the new trans in short order!
