pos ranger
- Jan 11, 2015
Okay bare with me because I see all over the internet these question are everywhere. I hate to bring something up that may have already been addressed.
My 93 ford ranger has a 4.0 v6, Manual transmission, standard cab body. when i first got the truck it was doing the notorious power loss. I replaced every sensor (EVERY). It continued throwing a code for Egr valve which my model has no egr valve anywhere (not new to mechanics and i do know what i am looking for) So finally i took the computer out and found a couple burnt out resistors. so i bought the new computer. The exact same one that came out F37F-12A650-Tc. And now it idles rougher than it did before and its throwing several codes 114 which I know this one isn't much to worry about with the engine not running, 629 Torque converter clutch failure (mind you it is a Manual trans), 566 Transmission 3/4 shift solenoid.circuit transmission (once again i have a Manual transmission) and finally code 157 Mass air flow sensor low voltage which is a brand new Maf this one i can return and try a new one no big deal at the moment but my problem is the damn auto transmission codes on my Manual transmission with a the same computer code from the factory.
any help would be greatly appreciated
