plasmaglow 9007
RavoHimself
RBV's on Boost
enfield, ct
That wattage is a little high to be using on the road. With the color of the bulb that may glare kind of bad. Not only that, you will need add a relay harness to your truck to handle the extra current draw of the higher wattage bulbs. If you want good bulbs, daniel3507 has the Philips Xtreme Power which run at stock wattage and are plenty bright.
do not run them on your stock head light wiring it will burn it up and cause a fire. you need to get the up graded head light wiring for them. i believe lmc truck sells it
