Pivot Bushing Replacement
Maverick
FoMoCo MoFo
Eureka, California
I'm currently installing the lift on my 95 Ranger, putting in new pivot bushings while the axle is out and on the ground. It's been years since I've replaced a set. I don't remember how I did it but what I do remember was that it was a pain in the ass. Anybody have any awesome techniques or tricks to replacing these things that I have yet to figure out?
I ran a 1.5" hole saw through the bushing when I had to do mine. Leaves far less rubber you have to burn out with a propane torch (this leaves the outer sleeve in place in which case you use sleeveless urethane bushings).
To get the sleeve out of the beam, I recall someone said they cut it out by slitting it with a sawzall.
You're not putting a solid axle in that?
I usually work em out with an air chisel and sort of fold them in on themselves.
Sent from my GT-S5830D using Tapatalk
The hole saw sounds like a good idea, think I'll give that a shot. No solid axle in the 95. Just doing a small lift (2.5" James Duff I had laying around) and 33" tires. Want a simple truck that drives good and can handle some mild wheelin'.
*edit* Air chisel sounds like a good idea as well, I'll give that a go first then resort to the hole saw if need be.
There is probably no need to slit the sleeves if you have an air chisel. I took mine out with a hammer and punch, and I did slit them. If you leave the sleeve in for urethane bushings I burn the rubber out then use a drill motor and wire wheel to clean the last of the rubber out of the sleeve. I use a bench grinder to cut the wire wheel down to the size I need while I spin it with the drill to keep it round. These pictures are from a Civic I worked on (didn't get any from the Ranger).
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Edit: Here's one I had to beat a sleeve out of-
[/IMG]
I ran a hole saw through mine like Junkie...then tack welded a big piece of pipe that had a larger ID than the OD of the sleeve, on the back side of the beam. Then used some 1/2" all thread from work, and some sqaure plates and an old socket (along with the impact gun of course) to press that bad boy out...then press the new one in.
basically.
I was kind of kidding. I have a way of complicating simple jobs on occasion. I think a ball joint press could work well if you have one around. Something like legoms did could also work well. I have used all thread and collections of sockets and other junk laying around that happened to be the right size plenty of times to press things in and out.
Thanks for all the replies people. I gave Sasquatch's method a try a first and it worked awesome, had both bushings out in about 5 min.
I dont know why no one's mentioned that James Duff pivot bushings DONT require the removal of the sleeve.
Other than that, I used a torch, chisel, and a BFH
