I am not familiar with your engine, so i did a bit of "quick" seeking to see if i can find any information.
I will guess your engine is this one....
and a fast parts search shows these rings with sizes. is this correct on your mic?
PACKAGE INFORMATION, metric
Part number: 2C5162
Contains: for 4cyl.
Bore: 89.00mm
Top ring: 1.20mm
2nd ring: 1.20mm
3rd ring: 2.50mm
PACKAGE INFORMATION, imperial
Part number: 2C5162
Contains: for 4cyl.
Bore: 3.504 in
Top ring: 1.20mm
2nd ring: 1.20mm
3rd ring: 2.50mm
and this is the composite of the rings in this Hastings box
PISTON RINGS DESIGN
Top ring:
Ring profile: BARREL FACE
Ring material: STEEL
Ring coating: CHROME
2nd ring:
Ring profile: REVERSE TORSIONAL
Ring material: GREY IRON
Ring coating: PHOSPHATE
3rd ring:
Ring profile: 3 PC. FLEX-VENT
Ring material: STEEL RAIL/ STAINLESS EX
Ring coating: CHROME RAIL
Information gleaned from here ... for fast references ....
Oil ring type3 PC. 3rd ring2.50mm. 2nd ring1.20mm.
www.ebay.com
As you are aware from doing engines years ago, the final hone surface needs to match what style of rings you are placing into the engine. a set of cast rings need a very coarse crosshatch as were a steel composite may need a finer cross hatch for getting the proper oiling to the glide surface of the rings. you may need to do a bit of reading to match your rings to the stone grade you intend on using.
Does any of this help? or you need further searching done?
cheers
ps, can't you re-measure the rings you took out of the engine? to see what size they were?
