El_Capitan
Does anyone know or have a link to tell me how to set pinion angle correctly? Ever since I re-geared to 4:88's I've had a vibration/noise around 45 or so mph. Drive slower it's fine drive faster it's ok also. I thought it was the driveline itself, so I had a whole new unit built and balanced, still the same. I've experimented with different angles using different lift blocks/shackles. and made it slightly better but it still does it. I'm not sure how detrimental this issue is, but I am concerned that it could shake the pinion nut loose or damage the t-case..
Soo, please if anyone has dealt with this let me know what you did to fix it
I forgot to say that this is in no way a tire balance issue I've worked at a tire store for 15 years lol
