Curious Hound
I know a guy with a website
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Feb 7, 2016
- Age
- 61
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Manual
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
Correct. The technically absolute correct way to do it would involve replacing the crush sleeve, pulling the axle shafts clear of the carrier and performing the torque sequence to crush the new sleeve and videoSo you really couldnt “properly” replace a pinion seal without taking it all apart, right? I did try that once, didnt have a differential failure but new seal did leak still afterwards.
I had marked the nut so it would be in the same spot when I put it back together but couldn’t really check rolling torque with the ring gear & carrier still in mesh with the pinion.
It sure seems like ford differentials have excessive backlash, Im sure its “in-spec” but wow, the amount you can turn the yoke with the ring gear stationary sure seems like too much.
Attain proper preload.
However, if I was very positively sure my pinion bearings were good, I would probably do what you did. The problem is that often the seal is going bad because the bearings are going bad and allowing too much play. That also the likely reason why you thought the backlash was excessive.
