Pinion nut torque versus bearing preload
dustyrangers
5+ Year Member
Colorado
It’s probably obvious but why are there two specs for pinions? Is nut torque 170 ft lbs to crush the sleeve and then you set the bearing preload to 18 in lbs?
The torque for the nut sets the general pinion depth. The preload fine tunes it and makes sure the bearings are riding properly. Not too loose, not to tight.
That question doesn’t really make sense... of course you do. Sorry :(
Wait I think I had it wrong... responded too quick. What I am reading is you torque the pinion nut to 170+ ft lbs while holding the yoke until you hit 18 in lbs while not holding the yoke?
Ok I got it finally... not sure why that one was so confusing.
I think the 170ft-lbs gets you "in the ballpark" then you slowly tighten until you get to the 18in-lbs of "drag" which let's you know the proper bearing preload has been achieved. It's been a while since I did that one, though.
170 ft-lbs sounds to me like a figure for a non-crush sleeve (spacer type) pinion setup.
With a crush sleeve, there really is not a set torque value for the nut, it is whatever it happens to take to crush the crush sleeve.
In my experience, crushing the sleeve runs in the range of 250-350ft-lbs on the pinion nut, at least on the 8.8" (it's a little less on the D35).
Continue tightening the nut to crush the sleeve... When the slack between the pinion bearings gets real small, continue tightening only in very small increments (like 1/12th turn at a time) while checking the bearing preload each time, since 18 in-lbs or whatever the bearings call for will come up VERY fast as the bearings make contact with the races (if you exceed the preload, the crush sleeve will be ruined and you'll need to start over with another one).
Also (maybe you already know, but just in case), leave the crush sleeve out while you are setting up your pinion depth, in which case you only need to lightly tighten the nut to set your bearing preload (use an old nut too, not the new one). Once you have a satisfactory contact pattern, then reassemble it using the crush sleeve and a new nut.
Hope that helps.
31317
There's a minimum torque... not an actual torque to spec.
....And is necessary to change the crush sleeve or you can still use the old one? my new pinion and ring comes without a new crush sleeve...Are all crush sleeve the same i need one for my Ford Ranger Splash 1995 3.0L V6
New sleeve.
Once a crush sleeve has been used, it has been crushed and is no longer the original length. When new components are installed, tolerances may add up differently and the crush sleeve may need to be a different length to get the preload correct. Best practice is to always start with a new one.
I learned on Ford 6 3/4, WER, 8 and 9 inch rears but the principle is the same- the bearing preload is the critical spec you're trying to hit. I install pinion nuts with my 1/2 impact and check preload once I feel the crush sleeve squash.
Never reuse a crush sleeve unless you want more practice setting up a rear end.
Thank you people but still with doubt about the crush sleeve of my Ranger 1995 ,is 7.5 and 3.73 ratio.
So you really couldnt “properly” replace a pinion seal without taking it all apart, right? I did try that once, didnt have a differential failure but new seal did leak still afterwards.
I had marked the nut so it would be in the same spot when I put it back together but couldn’t really check rolling torque with the ring gear & carrier still in mesh with the pinion.
It sure seems like ford differentials have excessive backlash, Im sure its “in-spec” but wow, the amount you can turn the yoke with the ring gear stationary sure seems like too much.
