Pics of my project
What kind of links are u usin for the rear? I never saw a setup like that before! THat thing should lay frame wiht that huge c channel in the rear tho!
It's a four link from Suicide Doors. They make them however you want. I went with this one because it's the beefiest one I've seen and this is a 5.0 truck with a T-5. I had the bars made as long as possible, hoping to plant the rear when I launch. Lol
The WATTS keeps the axle centered as the truck raises and lowers. A panhard bar works also but makes the axle move side to side. It doesn't move at all with the WATTS. Plus, I haven't seen many trucks using the WATTS.
The rear lift bars I'm just making myself. I studied a bunch of rear suspension setups that others have done and kinda "learned" how to do it myself.
I'm excited to get this thing running, there aren't any trucks like this around where I live. It's going to be on switches with 8 valves. And it does lay frame when layed out.:icon_hornsup:
Your on your way. How big of a tire you laying out with.
Pics of my project
[/IMG]
I'm not real sure. I have the Centerlines from my last 5.0 ranger. They are just 15". I'm prob gunna use em for now because I'm broke and can't afford new wheels. The notch will allow for much larger wheels/tires and the front can be reset for larger wheels.
Nice man, I wish I had the balls to do something like that. LOL So how did you do the watts-link? I've seen kits where they bolt on to the differential cover plate, but have never seen one like that before. Gives me ideas................
The Watts-link is the way to go because of what TS6034 mentioned. A panhard bar would work but you have to set it up exactly right. The bar allows the rear end to shift slightly during compression/rebound. A spring suspension may not notice this at all, depending on how close to the wheelwells you are running. With a bagged truck, the suspension can have a travel of 6+" and that much of a change would be noticable w/o the watt-link.
James
Here is the lift bar crossmember with the tabs welded into it
Pics of my project
[/IMG]
The lift bar crossmember welded thru the frame
Pics of my project
[/IMG]
Pics of my project
[/IMG]
The lift bars in place with the bags mounted.
Pics of my project
[/IMG]
Pics of my project
[/IMG]
Pics of my project
[/IMG]
Featured Ranger Based Vehicle
