Pics Of 2wd Ranger Lifts!
How much was that lift and is it a suspension lift? sorry i am just beggning to work on my 99
Yes it is a suspension ift and he said its a 6" lift. You will not be able to use that on your 99 I believe, that lift is for a 3rd generation ranger 93-97 you have a 4th generation ranger.
You can check out the info link at the top of the page for lift kits and stuff. or search you will find that lifts will cost a little more or be a little harder to piece together for a 99 vs a 93-97. Good luck and ask any questions you have after searching :icon_thumby:
4in Rough Country lift kit, wanting to add a 3" body lift next!!
3"spindle with coil spacers in the front and 3" blocks in the rear ,with 33" 12.50 15 bfgoodrich km2 mt
Hey man, what tires on your truck in this picture?
Just took the valance off, putting an 04-05 FX4 valance on.
This is my truck. 3" body lift with 2" coil spacers. Running 215/70r15 but want to put 30x9.5's on when I find an 8.8 LS with 3.73 or 4.10 gears. 3.08 won't take anything much bigger :annoyed:
Before
After
does this count? It sits higher than stock even though it is technically lowered.
Cut front coils, explorer 8.8 SUA and belltech shackles / 4 inch trim on fenders and bedsides with 31x10.50's on stock 15x7's
SOA and f150 coils coming soon
got the axle flipped and F150 springs installed.
Im going to have to lower it some or bend the beams. I am maxed out on the 2 1/4 degree cams and still have 2.2 and 3 degrees of camber. :bawling:
Just a Question
Whats better and Easier
Suspension or Body lift with out alot of modifications
I was thinking about raising my 94 2wd with a 4.0 I was thinking about putting 4x4 coils or even explorer coils in front and maybe 200? explorer leafs in back But I have no clue where to begin on my project. I have a bunch of stuff I want to do do to it being my wifes grandfathers truck who passed away so I want to keep it around for a while. Atleast till I give it to my daughter. Where do I post pics of my project from start to beginning. I do have access to a bone yard to get parts for cheap. So I can get a lot of parts wish they had a lifted 4wd I could scrape off the parts of of.
