Picking up new transmission tomorrow, NEED HELP
dasfinc
October 2011 STOTM Winner
MTOTM Winner
RBV's on Boost
Warrenville IL
I have a 98 2.5 2wd, Trans is on its way out
I'm about to pick up a A4LD *same trans* out of a 1999 3.0 2wd.
WILL THIS BOLT RIGHT UP!?!?!
Are the bellhousings different etc?
Any help would be dandy.
________
jailbreak
Yeah they should be the same 4R44E, not A4LD. The bellhouses are swappable IIRC. 2.5/3.0 use different patterns. I'm not sure the amount of work it would take.
Sry, yea 4R44E.
Does it involve tearing apart the whole trans, are just a few bolts holding the housing on?
________
medical marijuana doctor
6 bolts hold the housing to the case , undo them , then just swap bellhousings , then torque the bolts to 39 ft lbs in a star pattern
Thank you SOOO much, that is EXACTLY what I was looking for
________
TS125
