Pic request: engine crossmember
5.0
In the Middle
I'm looking for pics of the engine crossmember without the engine in the truck.
Any years, 2wd or 4x4, any engine... just give a brief description of what came in the truck. I circled the areas I want to see in the following pics...
1993 2wd 4.0
Not sure if this is what your after but here's mine when the 4.0L swap took place.
86 BII 4wd.
I am wanting to see which holes the crossmember has in it throughout the years and different models. Imagine a plate type with poly bushing 302 mount that would be drilled for several applications and was a bolt-in affair for each of them. It will only work if there wasn't a billion different crossmembers through the years and different engines.
