phenolic spacers and cams
Krowzer1139
i cant find any phenolic spacers for my 88 2,9 Bronco II does anyone know where i can get one? as far as cams on the 2.9 tech library it has a link to 3 diff cams what wold be the one i should get and will i have to remove the engine to do it?
For a phenolic spacer you're pretty much limited to making yourself a drawing and having a machine shop do it for you. Thats about it. And as for changing the cam you don't HAVE to remove the engine. Would probably be easier but not necessary.
what do i need to do to have them made as far as material and drawing what i need. would you say that adding a pro cam will make any difference? i know there are 3 different ones offed by camcraft would anyone sugjest one?
