road_warrior64
1993 Ford Ranger 2.3 5-speed. The clutch pedal has been getting mushy lately. I've discovered that if you are accelerating and push in the clutch pedal, it will go to the floor with little resistance. However, the clutch remains engaged and the truck continues to accelerate. If you let off the gas, the clutch pedal resistance returns. There is no slipping and the truck has 110,000 miles. I find myself pumping the clutch pedal to build up pressure. Friends say that it is the slave cylinder but I've read tons of post about air in the lines/bleeding issues. There was some fluid around the transmission / bell housing a few months ago but not so much lately. Before I attempt my first transmission removal, any advice or thoughts would be appreciated. Thanks!
JC
road_warrior64
JC
road_warrior64
