pedal going to floor and pass front dragging
flood
i have a 93 2.3 5 speed and the pedal goes almost all the way to the floor and the pass front brake is dragging causing a serious amont of power loss... i looked at the master cylinder and it was low so i filled it but if anything it got worse...i also notice my front pass center cap is missing and it looks like some grease has been slung on the wheel....please help
the caliper is probably seized. i would go ahead and replace the calipers, get a new dust cap and repack the wheel bearings with fresh grease. same thing happened to my truck. i noticed a serious lack of power and horrible gas mileage. figured out it was the front passenger caliper was rusted clamping down on the rotor. not good...
thanks phatcap that did the trick....
